61 - 80 of 204 Posts
shouldnt this be a stickey?
what year zx10 rims rit on the 03 z1000?
04- 07 anyways but I have read several posts about issue's with the initial run of 04 rims. The 04-05 front rim mounts differently than the 06-07 rim, different spacers and axle.
Wheel Conversion/swap for the Front says i can use a 1998-2002 ZX6 or a 2000-2002 ZX9 front wheel, can someone asure me that i will not need different spacers or axles?
FYI, ive got a rear ZX9 wheel with brake disc already and that was a straight swap no mods, no other parts, used same Z1K spacers and axles!
Update for exhaust:
2001 ZX9R header
Modification required: Collector hits rear shock, needs to be slash cut and flipped 180 degrees.
(This is a great mod to do)
Is this refering to the OEM ZX9 header or the after-market systems? Also, is this fact for the '03-'06 models? Visually the cylinder head is different on the '07&'08 so I'm not sure this is relevant to the new Z's.
Anyone....?
Below is an answer I found on another thread....
Let me save you some time. First off, your one can will definitely handle the "extra" exhaust. They don't make them that much different for single-sided exhausts, trust me. Secondly, don't bother with the ZX9 header-it will NOT work with the block on the GenIII (what you have) Z1000's. Though the displacement is the same at 953cc's, the configuration is different.
I think i have read that you can fit 2003 - 2006 dog bones to an 07 -08 bike ??
does this lift or lower the bike any 1 know how much
Discussion starter · #74 ·
I haven't tried it personally, but I'm 99% sure they'll fit just fine.
I'm in the middle of a move right now, and since this thread is getting kinda long and hasn't been stickied I'd like to just post up a fresh version of this one once I get squared away here at home.
Discussion starter · #77 · (Edited)
SUSPENSION / STEERING
Forks
- 03-05 ZX6R
Mods Required: ??
Shocks
- 03-05 ZX6R
Mods Required: The '05 636 shock will NOT directly bolt in. The lower legs on the 636 shock are 2mm closer together, and there is a spacer inside the shock linkage which will not fit into it. Need to have 1mm milled out of the inside of each shock leg to get it to bolt in.
- '05 ZX10R
Mods Required: I've personally got one, just haven't installed it yet. Mods TBD...
- 01-04(?) GSXR600
Mods Required: Minor clearance probs, slightly too short
Swingarm
- 98-02 zx6, zx9, and zx12
Dog Bones
- ZX9 or ZX6
Mods Required: None required
BRAKES
Rotors
- ZX10R Wave Rotors - fronts DO NOT fit, the mounting holes are offset
Calipers
- 2001-2003 GSXR 600/750/1000 calipers
Mods Required: May require creative brake line routing or longer hoses
WHEELS
- Rear
2000-2003 ZX9
- Front
1998-2002 ZX6
2000-2002 ZX9
ENGINE PARTS
ZX-9
- Cams ('98-'03)
Mods Required: There's a few things required for this. Here's a great thread on it:
http://www.riderforums.com/showthread.php?t=40581
- Flywheel / Stator / Cover ('98-'03)
Mods Required: Requires lengthening the wires by about 5-6 inches.
DRIVELINE
JT Sprockets
Front JTF1537.16 (Same as '04 ZX10 16 tooth)
Rear JTR1489.42 (Same as '04 ZX10 42 tooth)
Renthal (courtesy of Parts411)
Front 1212-0036-pu $36 or someone mentioned 400-525-16P
Rear R184U-525-42-HA-pu $56
Sprocket Specialists
Front 572S-16
Rear 706-42
EXHAUST
2001 ZX9R header
D&D
Mods Required: Fab new hanger
FUEL INJECTION / INDUCTION
Pod Filters, K&N Part #RC-1064
Mod Required: Airbox removal
BODY
Tail Components
- ZX6R
Mods Required: None
MISC PIECES
Clutch lever & Perch
- Almost any Kawasaki cable clutch & perch will fit
Rear Sets
I saw someone with a set of modified aftermarket ZX10 rearsets on their bike once. If you know who it was have them post up here on how they did it...
Man, this is the first time I've seen this thread. Awesome information, can't wait to check into some ZX9 wheels . . . Compstall we owe you :notworthy
Lets keep the list going, I don't have any new information but I can confirm that the 03-04 636 shock is a great mod!
