Swingarm swap!!!!!!!
38K views 77 replies 18 participants last post by  520650
#1 ·
I'm thinking of swapping my steel 650r swingarm for a Kawasaki Versys Aluminum swingarm. I've done some good homework on it but I'm wondering if anyone has ever done it, or may know if it will 4 sure work.????????
#2 ·
brp started that as a project, but had to stop it.
here are his project pics:
and some photoshops how it may look-a-like:
im really interested in doing it, but with the tĂĽv theres a lot more cash involved than just buying one...
also noone knows if the oem rearset fits with the wider swingarm.
so what kind of homework have you done?
#12 ·
i would love to do that swap but thats alot of down time and riding season is just around the corner. it does look much more sporty than the stock style swingarm. what are the differences in weight and suspension geometry?
#13 ·
if i remember right the geometry is the same, but its a little bit lighter.
nothing way over the top, but measurable.
also i dont think the downtime is thaaaaaaaat much.
just a few bolts if you get everything together before you start =)
but you also have to get a new chain and stuff right?
only interesting part is now how to space out the right rearset.
well a single seater wont have problems with that.
maybe rizomas fit better i think they make a small turn:
maybe thats enough =)
G
#20 ·
Swingarm swap
Hello every body i saw your site and i had to join. You guys need to see my 650rr that i had made for me.It is truly a one off bike.I cant load a picture not sure why,but you can see the bike at www.motogenex.com i look forward to talking to you guys and they found a big bore kit for this bike it will be a 700cc soon.
Chrismgx
#50 ·
Chrismgx
Where did you find the big bore 700cc kit? Thanks
#23 ·
FEROCIOUS! Now that is what Kawasaki should wake up and do! More aggresive styling to win more customers.
:agree:I love the exhaust angles and tips. I really love the way that the lower fairing extends back and doesn't just cut off. It makes the bike look "full". Do you know what I mean?
#24 ·
Kawasaki
+1 :headbang:
G
#25 · (Edited)
Swingarm swap
Here is the curent picture of my bike. This bike is 315 lbs wet and its a ball to ride. It takes no effort to lay this thing in a turn slame your knee on the ground and pass all the 1000s ( on the out side ) at track days. The bike is just planted to the ground and its a blast to ride on the street. If you are ever in northern CA you need to stop buy Motogenex, they built this bike i cant thank them any more.
#28 ·
Is that a fiberglass tank?And I think you're being a little optimistic on the weight.
#27 ·
that thing looks sick. they do some awesome work. wish i had the cash to throw at my bike. and 315 pounds damn thats a diet....
#30 ·
The tank is fiberglass and kevlar and the bike is 315 wet trust me.
Our Moto-St bike weighs 360lbs dry fuel tank.
We have a custom aluminum subframe, and fairing bracket.
Here's a break down of part weight:
Full frame:60
Versys swingarm 15
Engine and Throttle Bodies :140
Front wheel,tire, and rotors:30
Rear wheel,tire,rotor,sprocket and carrier:32
Forks&Triple Clamps 32 Your using an upside down set, which weighs 5 lbs more.
Wire harness and components:8
Bodywork: 11
Radiator and fan:5
Exhaust: 9
Calipers and master cylinders:9
Stock battery:9 Moped battery:4
Shock:6
Rearsets:6
Misc nuts and bolts:4
I see you're using a kick stand, add another pound.
Fuel is 6.25 per gallon x 4 at least=25lbs
G
#31 ·
swingarm swap
Wow are you sure thats a race bike, thats heavy. When i raced i AMA i learned how to save weight. This bike has rc211v body work you cant get this in the states,alm 1 off sub frame,dymag wheels,gsxr1000 ft end,carbon tail and the list goes on and on. When i raced in CCS i was on a fzr 560 and that was 350 wet so ithink your race bike can still shed some pounds... I tell you this bike is 315 wet with no kick stand in track trim.
#32 ·
Ever hear of a guy named Ed Key? Races the trickest, lightest SV650 there is.
305 lbs. Ti and carbon everything. Every possible bolt is drilled.
360lbs is lightest a LW or ST class bike can weigh, empty.
It's not that I don't beleive you, it just I find it very hard to. Sorry,
the #s don't add up. If you had a full aluminum frame, and ti everything, yes.
G
#33 · (Edited by Moderator)
swingarm swap
I think i know the name from my CCS,WERA days. I know its hard to believe you might want to call motogenex.The bike does only track days my racing days are over. The body is carbon,fenders,tail and most of the 1 off parts are alm,ti and mag.. Good luck this year racing your 650 remember beat up on the sv for me....
