Clock will not stay set!!!!!!!!!!
23K views 29 replies 18 participants last post by  m.b.leighton
#1 ·
Now I thought I checked all the fuses but I didn't find any that were popped.
Seems like everytime I park the bike (or stall :( ) the clocks & trip computers reset. Logic tells me its cause a fuse for the ECU is blown and cutting the drip to keep the clock on when the bike is not on. Any ideas? Searching for "clock" didn't turn anything up.
#3 ·
Why did you check all the fuses? You might want to look in the service manual at the electrical diagram and see which fuse goes to that circuit. Then pull that fuse and replace it. The fuse may not look bad but it could be. But then I would be concerned as to why the fuse blew. You been doing any work in that area recently?
Also, check the wiring connections for that circuit, and then check the harness itself to make sure you don't have an exposed wire.
This is the first I have heard of this on a bike without a dead battery.
#30 ·
Why did you check all the fuses? You might want to look in the service manual at the electrical diagram and see which fuse goes to that circuit. Then pull that fuse and replace it. The fuse may not look bad but it could be. But then I would be concerned as to why the fuse blew. You been doing any work in that area recently? Also, check the wiring connections for that circuit, and then check the harness itself to make sure you don't have an exposed wire. This is the first I have heard of this on a bike without a dead battery.
Diagram only shows instrument cluster as a unit!
#4 ·
I was searching between the three forums, forget where I saw it but someone was having the same problem with an old battery. I am pretty sure the battery in my bike is original so that could be the culprit. It's been like this since I first got the bike, and the bike only had 250 miles when I got it so I don't think it's a matter of work or anything. Everything else works fine.
#5 ·
The battery has enough juice to start the bike, but not enough to keep a mA circuit going? Curious.
#9 ·
There has to be a "keep alive" voltage feed for the clock, that doesn't shut off when the bike is turned off. First thing that I'd do, in your position, is check the fuses thoroughly. Then, if I didn't find any bad fuses, I would pull off the connector to the display and check for corrosion. It's unlikely to be the battery, if the bike starts well, but a constantly live line will be more prone to corrosion.
#11 ·
That would make sense. Doesn't the meter hold the time/trip meters if the battery is disconnected for a short period, though? Or does it lose it as soon as the battery is disconnected?
I know the one time I removed my meter it lost those things but mine was off for a few days.
#17 ·
I am having the same problem. I have checked the cables and did replace the battery. Everything was good for about 3 days going back and forth to work. Then the forth day not enough juice to turn over the engine.
#20 ·
Same thing happening here. Trip odo and clock reset after the bike has sat overnight (16 hrs). But, they do not reset when I park it in between commute (7 hrs). This started happening about a week ago... I was wondering why I wasn't racking up the miles like I used to! Trip A was resetting, which made guessing when to fill up a chore.
I only run some small LED in my givi bags.
Bike still has enough juice to crank over fine, however the battery *is* 4 years old. Time for a new one?
#21 ·
Probably. But every bike owner should have a multi-meter and a small battery maintainer; total cost, maybe $40.
If you presently have neither, check the connections to that battery and start shopping for a new one.
If you get an AGM type it should last MUCH longer.
At some point, you need to check the charging voltage.
#22 · (Edited)
Thanks ER. I do keep the battery charged up over the winter months. A multi-meter, its one of those tools I think I should have, but would not know what to do with it :)
I'm just a simple caveman, and your world of "electricity" frightens and confuses my primitive mind.
Edit:OK. I picked up a multimeter.....I'm going off to youtube to learn what I just got, but if anyone wants to chime in with what I should be doing with it, thanks in advance.
#23 ·
You could do like I do, use it for a tool box space taker upper! :) I can take it out when people are around and look really smart and professional. Lol
Seriously, I kind-of know how to use it, just not every setting for what situation.
#24 ·
My bet is with Papa_Complex -- the "keep alive" wire is probably loose (assuming the fuse is okay). It's the white/black wire going into the intstrument cluster for MY2009-2011, and the orange wire for MY2012-2014. You should measure +12volts from these wires (tap from the connectors, see service manual for details). If the "keep alive" wire measures +12volts, then it looks like the intrument cluster is now suspect.
#25 ·
Thanks, I will try & track down that wire today.
FWIW, battery was 12.4V, dropped to around 10 when cranking, and 14 & change at idle.
I noticed the positive terminal screw was finger loose, maybe 1-2 turns. Wonder if that could have been a potential cause?
#27 ·
Yes absolutely.
Your initial reading of 12.4 is a bit low but not enough to cause trouble....even with the clock.
Tighten those cables. That will likely fix your problem.
The other readings are well within the range of "good".
#28 ·
FWIW it was the battery. Bike used to struggle to start, now with a new battery it cranks over in like 1 revolution if the engine is warm.
