Rattling in mid range
This is a discussion on Rattling in mid range within the ZR-7 Maintenance forums, part of the Kawasaki ZR-7 category; Hi I'm getting a bit of a rattle in the engine when I'm in around 4000rpm to 5000rpm. It seems to happen in all gears ...
Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    Newbie skoobi's Avatar
    Mar 2014
    Pembrokeshire, Wales, UK
    13
    Hi I'm getting a bit of a rattle in the engine when I'm in around 4000rpm to 5000rpm. It seems to happen in all gears as far as I can tell... I've recently changed the spark plugs for iridium NGK, piper cross air filter and oil filter with new oil but it's still there. Anyone had this before at all...
    Also do I need to rejet the carbs if I've changed the air filter to a piper cross???
    Cheers
    Chris
    Johnny Blue Lightnin'
    JonF's Avatar
    Mar 2002
    Felton, DE
    55
    12,132
    132 times
    How many miles on the bike? Did it start after replacing the air filter? You could be running a bit lean. ZR's aren't know to ping but it is possible. Try some higher octane gas and see if it stops.
    Feb 2014
    Yukon, Ok
    3,348
    1015 times
    How long's it been since the valves were adjusted?
    Mar 2004
    Delaware
    1,059
    42 times
    I always start with the easiest and cheapest solutions, so before anything else I'd confirm that the exhaust collars weren't loose, particularly as you mentioned a "rattle."
    2015 Versys 650 ABS
    (Former owner 2003 ZR-7S)
    Mods/Farkles: Nat'l Cycle V-Stream windscreen, Givi hand guards, BMW grips, Omni-Cruise throttle lock, Motowerk mirror extenders, Denali Mini Soundbomb horn, SW-Motech luggage rack and side racks, Givi E-22 side cases, RKA 13L tank bag, RKA 36L rack bag, Motorwerk side stand foot, Motowerk highway peg set-up, SW-Motech wide foot pegs, SW-Motech GPS shelf, Hyper-Lites, seat riser mod, decalectomy
    2,199
    180 times
    Quote Originally Posted by Doug Hyde View Post
    id second that..mine liked to work loose every 500 miles or so..till i got mad and double nutted them
    Mar 2014
    13
    Cheers guys only today i've managed to got time to check it ill let you know what i find...
    Its done a fair bit of milage (46,000 miles)...
    Ill try a few things today and see what it does
    5,052
    1041 times
    Are you sure it's an engine rattle and not a rattle of either the fairing or the tail light assembly (or something else)?
    Mar 2014
    13
    Ye its definitely engine. I've put rubber washers on the fairings. Ive booked it in for the carbs to be re-balanced next week so hopefully they can take a look while its there...
    Newbie cosmix's Avatar
    May 2019
    16
    Hi
    I am new here.
    I have a very similar problem. My engine emits a knocking sound only in the mid-range. Does anyone know what was the cause in this case?
    Up-And Comer CB_Phil's Avatar
    Apr 2015
    29
    Not sure about the rattle, but the knocking could be fuelling issues. How is the power during the knocking?
    May 2019
    16
    The bike runs smooth, whithout any problems except the rattle between 3000-5000rpm.
    Apr 2015
    29
    I'd still look at fuelling 1st. Check plugs & air filter, then move onto carb balancing & tappets. Even if they aren't the cause, they are still good to do.
    May 2019
    16
    All this is already checked, even the valve clearance. Sounds appear up to 3000rpm. There is nothing to hear before reaching 3000rpm.
    Apr 2015
    29
    Plugs look good. Check the camchain h tensioner?
    May 2019
    16
    When setting the valve clearance I am also checked the tensioner. Looks OK.
mid range engine rattle
rattling on a zr7
