ZR-7S Valve Adjustment with pics 1 - Page 4
This is a discussion on ZR-7S Valve Adjustment with pics 1 within the ZR-7 Maintenance forums, part of the Kawasaki ZR-7 category; Certainly no issues with performance on it yesterday and it revs freely, just a slightly annoying noise that was not there previously. If I had ...
Page 4 of 4 FirstFirst 1234
Results 46 to 55 of 55
Like Tree2Likes
Thread: ZR-7S Valve Adjustment with pics 1
  1. #46
    Up-And Comer Jerry BB's Avatar
    Jul 2016
    45
    11 times
    Certainly no issues with performance on it yesterday and it revs freely, just a slightly annoying noise that was not there previously. If I had a loud pipe you could not hear it.
    I have to change the rear disc tomorrow so I'll have another look & Listen to it.
    Regards,
    Jerry BB
  2. #47
    1,920
    625 times
    Like Shaky said, could just be the cam chain. Not to mention, with the hot weather, and some miles, the oil gets a bit thinner and makes those valves, cam and chain, and other internal moving parts more audible. It's amazing how much quieter they are with an oil change!
  3. #48
    Jul 2016
    45
    11 times
    I did change the oil only a few weeks back, but it has been very warm here and I had been belting it bit before I noticed it. It sounds a lot quieter today, so I'll see what happens over time and keep an ear out for it. It is only a very minor rattle/tapping so I don't think I need to panic just yet!
    Thanks all.
    Regards,
    Jerry BB
  5. #49
    Up-And Comer damage.inc's Avatar
    Sep 2008
    26
    Quote Originally Posted by Xinix View Post
    This is great. Especially the pictures help.
    Once I got the gasket, I started putting everything back together. Before putting the cover back on the valves, I thought I would check the valves again and ... there was no clearance anymore, nihil, nada, zero, nothing. They were all slammed close to the cams ...
    This guy's misery is over 8 years old, but I just ran into this EXACT same problem. Measured all clearances and waited 10 days for the two shims I needed. (six of eight were fine) Replaced the shims and got ZERO clearance on 7 of the eight, .002 on the eighth. I've disassembled and reassembled about 5 times. Engine turns over smoothly and what feels like very normally. Timing appears to remain correct.
    I've done 4 or 5 successful valve adjustments on dual cam single cylinder bikes, so I am not exactly a newbie, but this bike makes me feel like a complete idiot.
  6. #50
    Sep 2008
    26
    Quote Originally Posted by damage.inc View Post
    This guy's misery is over 8 years old, but I just ran into this EXACT same problem..
    OK, (takes deep breath) FYI, I think I have my valves figured out. I have no idea what went wrong with my initial measurements, but I kind of gave up and started over.
    I pulled all shims and bought 8 new ones, with a nice selection of smaller sizes. The valves I deemed the tightest got an adjustment of up to 0.25mm (i.e. 2.60 >2.35). I estimated everything else on the thin end and replaced all 8 shims with smaller ones. Some were still tight AF, but gradually I was at least starting to get measurements!!
    After assembling and disassembling many times, (approximately 6 total) I was finally able to get 7 measurements. (My smallest feeler is .002") I STILL had to buy three more shims to get everything right. I now have every clearance at either .005" or .006"
    I had to mathematically "back into" the original clearances, but they were as follows:
    Exhaust (inches) (1234): .004, .002, -.0037, .001
    Intake (inches) (1234): .002, .003, .004, .003
    On a side note, the blue Permatex matches the candy lightning blue pretty nicely!
  7. #51
    Sep 2008
    26
    Also FYI, it is a 2000 ZR7 with only 11,500 miles. I just bought it last summer. The PO took it to the dealer only (so he says), so my guess is that it probably did get the break-in adjustment, but that's it.
  8. #52
    Sep 2008
    26
    My advice is this: If you're going to own this bike for many years and many miles, and you want to do your own maint.... buy a shim kit.!!
    I had a free weekend, so it didnt kill me, but I had to keep assembling and disassembling because I was "moving" the smallest shims around to different valves to try to get a min. measurement. A kit would have saved me a lot of hours.
  9. #53
    Rising Star locojim's Avatar
    Mar 2008
    Streator Illinois
    302
    Even though it says not to cut them to the right thickness I have had my buddy grind some to the correct size at a machine shop.
    They still passed the hardness test and have been fine.
  10. #54
    Newbie RussoTuristo's Avatar
    Mar 2019
    Hi, I do not see the photo. I adjusted the valve many times and found out that the ideal clearance is 0.10-0.11mm, with this adjustment the engine runs quietly, if the gap is more than 0.12, an unpleasant sound is heard
  11. #55
    Rising Star TWOQUIDKEV's Avatar
    May 2011
    Lancashire, UK
    221
    42 times
    Quote Originally Posted by RussoTuristo View Post
    Hi Russo, if you look at post #31 I uploaded a word doc to Dropbox, just follow the link, I've just checked it and all the pics are there in the doc.
01 zr750 cam timing specs
2001 kawasaki zr7s timing specs
kawasaki zr7 valve adjustment
kawasaki zr750 cam timing marks
valve adjustment 2001 zr7s
valve adjustment on zr750
zr750 cam timing manual
zr750 valuve clerances
zr7s valve adjustment
