z750s to z1000s
z750s to z1000s
This is a discussion on z750s to z1000s within the Z1K/Z750 Performance Upgrades forums, part of the Kawasaki Z1000, Ninja 1000, Z800, Z750 & Z-750S category; i love my z750s but the torque is a bit boring. i dont need anymore top speed after looking at the threads on here decided ...
Page 1 of 4 1234 LastLast
Results 1 to 15 of 57
Thread: z750s to z1000s
    Up-And Comer monty9120's Avatar
    Apr 2017
    54
    z750s to z1000s
    after looking at the threads on here decided to do the conversion myself
    as you may be aware the z1000 didnt come in a z1000s version so this will be quite unique. plus i like the bike
    plans are to fit a full z1000 engine rather then swapping pistons out etc.
    i will put any snags on here too
    plans are
    -z1000 engine
    -z1000 throttle bodies and injectors
    - original z750 exhaust with fuel end can
    taking things apart is pretty simple all plugs are different. so makes it easier. the airbox doesnt come out which is a pita
    getting the new engine back in is the biggest issue lining up the mounts
    i have come across a few snags.
    -the z1000 has an oil cooler and i dont know what to do with the pipes from the oil filter area
    - i was hoping to fit my 750 front sprocket but the gearbox outter doesnt have as much teeth as the z750 gearbox has. this means i cant bolt the sprocket up
    has anyone got any tips for the above
    Apr 2017
    54
    looking at the front sprocket size. the following shows the z750 sprocket is much thicker thats why its not worked
    obviously a z1000 has a different chain a 525
    so i had to look for a 15 tooth front sprocket (same size as my original) with the same measurements for a 520 chain
    seems like a gpz400 may be the answer. will try and see.
    10,304
    2255 times
    You are doing this outside in the garden? That is quite an undertaking. What will the weight difference be when all finished? Will all the other components of the bike handle the increased power? weight?
    Apr 2017
    54
    I did some of it on my drive and some in my garage when it rained
    The engine isn't too heavy just hard to navigate the engine in on its own
    Time will tell on brakes etc loads have done the piston swap on a z750 so effectively the same thing
    Rising Star PerryG's Avatar
    188
    14 times
    Z750 engine is likely heavier the pistons, valves and clutch would be the only parts that'd be lighter, offset by more meat around them <---(thicker liners) and around the smaller valves, smaller combustion chamber too, none of this is filled in with air so the liners for instance are gonna add weight to the engine. There won't be enough weight difference between the 2 to notice but you will notice the power difference.
    188
    14 times
    At the very bottom of this page before clicking on this post the "er6 sprocket on a z750s" post has an entry by me about possible, what I think are practical gearing options that you may find informative about your sprocket conundrum. I don't know how to copy a link and put it in this post. Sorry about that
    Apr 2017
    54
    Thanks. I have ordered the one above if not i will try your suggestion
    Worst case I'll buy a whole z1000 sprocket set
    Apr 2017
    54
    some more updates.
    - the z1000 throttle bodies came today. what a pig to fit in the gap lol. theres just no room finally got them in
    - plugged everything in. all plugs are different. i did take pictures as it was taking things apart (this helps alot)
    - had lots of leaking radiator pipes. turns out the clips i brought werent up to the job. all replaced
    - bolt to hold gear selector onto the gearbox broke. so had to drill that out
    - fitted z750 downpipes and exhaust
    still waiting on the front sprocket but everythings ready to rock and roll
    Attachment 110665
    Attachment 110665Attachment 110673
    Apr 2017
    54
    some more updates.
    Apr 2017
    54
    Apr 2017
    54
    Finally had the bike running and moving today
    The front sprocket seems to be ok and fits well
    Trouble is at first I thought the front and back sprocket were slightly out of alignment
    A couple of questions is the z750 rear wheel and z1000 wheel the same
    Does anyone know what the thickness of the rear sprocket on a z750 and 1000 is
    Looking on eBay they show the same so am I worrying over nothing
    Aug 2012
    Athens, Al
    147
    Sprocket bolt pattern is the same but 750 is a 520 and 1000 is a 525. Run the 1000 width if you don't want to go through chains I'm running 15/46 can't make a 520 chain last 10k miles on my 750/1000.
    Apr 2017
    54
    Do you have a 1000 engine or just the bits on a z750 lump
    I'm aware I'm doing this a different way to others that's why I'm posting any snags i hit
    On meaauring the front sprocket on the old and new engine seems the front on the 1000 is about 2mm to the left
    As it's on a shaft and you can't do anything with that
    Possibilities are
    Move rear sprocket out 2mm (if possible)
    Change to a z1000 sprocket set
    Now that brings on other issues. Does the z1000 wheel have the same dimensions as the z750 wheel
    If not I could buy a sprocket set and it will still be out by 2mm
    Just so your aware having a 1000 engine is bloody awesome lol
    From the pick you can see the new front pulley a little rubbing
    As close as you like but not quite there
    Aug 2012
    Athens, Al
    147
    750 lump I know the stock 750 sprocket was offset and the aftermarket just free float on the shaft the parts numbers are the same so shouldn't have an issue with aftermarket.
    Apr 2017
    54
    its a 1000 lump so its slightly differenct. i will get a laser and see. have spaced the rear sprocket about 2mm. its not quite there so need to adjust when i get some time
    the actual engine runs well. will dyno it to see if the downpipes and ecu are restricting it
    its quicker but not the major jump i was expecting
iphone??
will the kawasaki z1000 engine fit the z750
