150hp genII Z750 - Page 2
150hp genII Z750
This is a discussion on 150hp genII Z750 within the Z1K/Z750 Performance Upgrades forums, part of the Kawasaki Z1000, Ninja 1000, Z800, Z750 & Z-750S category; @Balogiannis. I started my own thread for my bike, but thought I would ask here also. Would you be willing to flash an ECU and ...
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
    57x
    57x is offline
    Newbie 57x's Avatar
    Jul 2015
    California
    16
    Would you be willing to flash an ECU and send it to me. Your tune looks to be somewhat close to what I need except my smaller throttle bodies. I don't have access to someone local that can flash. I can use a Power Commander to dial in the differences.
  2. #17
    Up-And Comer monty9120's Avatar
    Apr 2017
    54
    I’m still looking for a good power commander map for a 750 Ecu with 1000 engine does anyone have one
  3. #18
    Aug 2012
    Athens, Al
    146
    Probably not much help but this is my map before I did the cam swap. Only problem is it was running Zx10 throttle bodies and gsxr 750 injectors 20190214_194603_1550195343445.jpg
    Rising Star PerryG's Avatar
    183
    14 times
    So I've been looking for a cylinder base gasket for my 07 Z750s soon to be a 950, only gaskets I can find are oem thickness. I've already got a thinner cometic head gasket but it seems like they don't make thinner base gaskets for z750/z1000 engines, I'm wondering if an 03 zx9r gasket would work, they are available in .020" and .010" thickness, I'll be going with the .010" one if anyone here could tell me they will do the job it'd save experimenting and maybe buying something I cant use, any opinions would be appreciated and the prior posts here seem to indicate a lot more knowledge about engine modifications for our bikes than I have.
  6. #20
    Newbie Balogiannis's Avatar
    Oct 2014
    19
    Quote Originally Posted by monty9120 View Post
    I'm sorry I can't help you with that,I maybe have some PCV maps but they were made with 750 ecu,1000 engine with ZX10 throttle bodies and zx636 injectors
  7. #21
    Apr 2017
    54
    Yes please
