Ehaust Butterfly Valve
This is a discussion on Ehaust Butterfly Valve within the Z1K/Z750 Maintenance forums, part of the Kawasaki Z1000, Ninja 1000, Z800, Z750 & Z-750S category; Hello fellow ZED owners. I seem to be having an issue with my fuel injection warning light. I am getting an error code of 63 ...
Results 1 to 15 of 18
    Up-And Comer logspec12's Avatar
    May 2009
    Virginia Beach, Va
    31
    Unhappy Ehaust Butterfly Valve
    Hello fellow ZED owners. I seem to be having an issue with my fuel injection warning light. I am getting an error code of 63 which tells me it's the exhaust butterfly valve. When I took the side cover off the valve doesn't look anything like the one in the service manual. Has anyone ever come across one that looks different? I don't want to continue riding it if it might do some damage. Any ideas? I'm will be attaching some pictures so you can see what I'm refering to.
    May 2009
    Virginia Beach, Va
    31
    Here are the pictures I was taking about. I'm really confused as to why it looks so different.
    Site Elder jsmith8008's Avatar
    Dec 2008
    Seattle, Washington, USA
    863
    You do seem right. This is from the second gen manual. What years your bike?
    [IMG][/IMG]
    ZR1000B7F, KL650E9F
    Pacific Northwest Riders.com
    www.pnwriders.com
    Washington Sportbikes.com
    www.washingtonsportbikes.com
    Site Elder fast_stakes's Avatar
    Apr 2006
    Central Iowa
    735
    I'm assuming you bought the bike pre-owned and it has an after market exhaust on there. That plate looks like a plate that was installed to fool the computer into thinking the servo cables were still hooked up. The points on either side would contact the servo motor housing making the computer think the valve in the exhaust is fully open or closed without having the valve there.
    Sometimes it takes a whole tankful of fuel before you can think straight.
    “Insisting on perfect safety is for people who don’t have the balls to live in the real world.”
    – Mary Shafer, NASA Ames Dryden
    May 2009
    Virginia Beach, Va
    31
    It's a 2007. I bought it used with a Scorpion exhaust already installed. Will having this problem effect anything major or can I still ride it?
    Apr 2006
    Central Iowa
    735
    No, it will not affect anything major. Without the butterfly in the exhaust, all it will do is give you an annoying light on the dash.
    Site Elder schap's Avatar
    Aug 2007
    Mason, Ohio
    525
    Interesting. Because it's a 2007, I don't think you need that plate to fool the ECU...it doesn't care (at least mine doesn't). Can you remove the plate? Be careful not to turn the motor while removing the bolt.
    Let me get some video of mine to share.
    Schap! (or "Schlap" to some)
    2007 Kawasaki Z1000 w/ Full Race 4-2-1 Akra, PCIII, K&N, Airbox Mod, Engine Ice, Pro Taper Evo RM Low, Bar End Mirrors, Evotech Tail Tidy
    Aug 2007
    Mason, Ohio
    525
    Sorry for the crappy lighting in the video. Hopefully, you can still see that the servo motor does not need to touch/bump anything to trick the ECU when starting the bike.
    http://www.youtube.com/watch?v=GcvkDa42tfo
    I wonder if your plate is actually stuck or hitting one of the sides, which tells the ECU that the motor is stuck.
    Supreme Being Azweepay's Avatar
    Feb 2008
    Panama City, FL
    55
    1,085
    Good point Schap. There seem to be some scratch marks by the right side tip. Is it making contact and dragging?
    Aug 2007
    Mason, Ohio
    525
    Quote Originally Posted by Azweepay View Post
    I hadn't noticed the scratches. The tip looks like it could be bent.
    May 2009
    Virginia Beach, Va
    31
    The tip isn't bent, it looks like it was made that way. I haven't tried to run it without the plate installed. I'll try it when I get home from work. I just found it strange that it only recently became a problem. I was unaware that there was a plate there. I have black electrical tape over the light so I can't be annoyed by it anymore. I think I might need a new servo motor though. Maybe it just quit working. I did notice when I pulled the plate off and removed some of the rust and put it back on the light went out at first, then came back on. The motor did rotate the plate and seemed to work at first and then it just stopped in the position it was in. I hope I don't need a new motor. That'll be about $185.00.
    Aug 2007
    Mason, Ohio
    525
    Quote Originally Posted by logspec12 View Post
    ...The motor did rotate the plate and seemed to work at first and then it just stopped in the position it was in. I hope I don't need a new motor. That'll be about $185.00.
    So, the motor/plate doesn't turn when you first turn the key to the on position?
    If so, then the motor itself may be shot or just need some adjustment/maintenance. The plate itself looks rusty. Have you exposed the motor to much water (rain? washing?)? (Thinking how to avoid this in the future if you have to get a new motor...)
    EDIT: The servo motor eliminator would be cheaper at $110 than buying a new motor: http://www.ivansperformanceproducts.com/other.htm
    Last edited by schap; 06-09-10 at 10:06 AM. Reason: Link to servo motor eliminator
    Newbie MaxWedge's Avatar
    Jun 2010
    SE PA
    18
    Yeah that pully looks like it's scratching the surface behind it, and it's definately not the stock piece. Take it off (the rusty pully) and see if it fixes it. If not get the Ivan's piece listed above, or if you can find one cheap, a used servo motor.
    May 2009
    Virginia Beach, Va
    31
    Schap,
    I removed the pulley and the FI light still stayed on. The motor shaft seems to have about an eighth inch play in it so when I pulled on it a little the motor started to work again and the light went out. Very strange.
    Supreme Being Black Sheep's Avatar
    Feb 2008
    Raleigh, North Carolina, USA
    2,779
    219 times
    I got the FI warning light once after removing the cables. But I just rotated the pulley a few degrees and then turned the key on again. It seemed to be happy once I "aligned" it in a way it would accept and stopped throwing the error. Not sure if that is your issue, but it's free to try!
    2012 Kawasaki Ninja 1000 | 2013 mid-fairings for an all Metallic Spark Black finish | OEM Solo Seat Cowl | Puig Smoke Windscreen | Targa Fender Eliminator
    Rizoma Rear Turn Signals | Sato GP style swingarm hooks | M4 GP Style slip-ons | Speigler SS Brake lines | Stripped and Polished wheel lips
    _______________________________________
    North Carolina riders check out: NCSportbikes.com
2007 z1000. code 34
2008 kawasaki zr750 fault codes
butterfly valve z750
errore 63 kawasaki
exhaust butterfly valve actuator
how to eliminate the butterfly valve, service code 34
kawasaki fi code 63
kawasaki ninja 07 code 63
what is code 34 on a 2007 ninja 1000
z1000 butterfly valve
