41 - 44 of 44 Posts
Moderator
Ah memories.....Did you ever get the ZX8 working, or get the 7 motor in the 6 frame? Did your friend ever get his shop?
Discussion Starter · #42 ·
no, no and a resounding no... i am very sorry to say that i wound up spending all my money on a new house and have been trying to recover from that ever since, lol... i am currently looking at a sizable promotion at work though, so i may be able to start this spring/summer... I'd rather not work in the cold any way...
i think i am going to use the ZX9R frame instead of the 6R though... should be a bolt in install. and the i will stroke the engine simply by using to different year models... the earlier model 7R had a longer stroke, 91-96 i think... and the newer models, 96-2003, had a bigger bore w/shorter stroke, both engines right at 749cc. Put the older crank and rods in the newer block with pistons and you have your self a stroked 7 sitting right at ~793cc with a bhp of around 128 at the rear wheel... more than what my car pushes lol...
but right now i am still pricing parts and all, but i will keep you updated on how it is coming...
the reason it would fit into the 9 and not the 6 would be due to the difference in the size of the frame. Why ask a question then not listen when someone tries to tell you something?
I think someone did try to do it or DID do it and it required shaving some of the frame and cutting and relocating the upper motor mounts, or maybe im thinking of a diff bike/motor combo but I was pretty sure thats what it was.
and what does the tail on the 650 have to do with your original questioN?
The frames are different based on their air induction and the the ports in the front of the frame more power more ports through to the front farren section and also differences in the topend an radiator size. When you go in compression ratio I believe it also ups you coolant also on the 7 your motor mounts are you creshpegs as well or rollers. The 9 into the 7 is easy they make a kit for it....just do that trust me you won't be that fast. You'll be heavy as hell and you'll get passed up around the twists and turns by the 600/750 some dude catching a good hot tire with some decent rpm is going to be knee down going passed you like a missile he's Gunna look back at you for a split second and that's when you woulda wished you would have built the 7 in 7 frame instead of being one of those people that hacks up super bike gold and still doesn't end up with a working bike
41 - 44 of 44 Posts
