1 - 2 of 2 Posts
My friend wrecked his zr7s and wanted me to use the motor for a project. Is there a way to get this thing to run without all of the wires? I just wanted to use the kill switch starter and that's about it. Is this possible or do I need to use everything?
You'll need at least some of the wiring. You can remove the wiring for the lights, bypass the kill switches on the clutch and kickstand and even the ignition switch, but you'll need the coils, rectifier etc.
The fuel is straigth forward being gravity/vacuum carburetors but you'll need to figure out the spark end. OEM wiring it likely the easiest but if you want to mess around you could use an aftermarket ECU setup.
1 - 2 of 2 Posts
