21 - 21 of 21 Posts
Z750s cheap alternative front shocks and brake upgrade if you can service your own equipment is
ZZR600 with preload and rebound, 15w oil 150mm. These forks are 40mm longer over stock so have to be dropped through the yokes handle bar raisers are need to get more than 25mm.
spacers on axle have to be shimmed 0.5mm each side and thats it.
I'm 135kg rider so bare this in mind if your if your below 110kg go 10w as it will be to harsh.
21 - 21 of 21 Posts
