41 - 48 of 48 Posts
Kawasaki z650 abs 2017 real street fighter
Discussion Starter #45
And what next ... And then we go to the main question how did the Kawasaki Z650 lose all his strength along the path of evolution ??? And here it is worth taking a close look at both models and compare and what the designers have changed, allegedly in favor of improving the characteristics of the former ER6N...
122877
Discussion Starter #46
Let's compare two motorcycles side by side and take only what interests: engine data.
ER6N
Cylinder arrangement2-cylinders, inline
Bore & Stroke83,0 x 60,0 mm
Displacement649 cm³ (39,6 cu in)
Compression ratio11.3:1 – ER6 (2006-2011)
10.8:1 – ER6 (2012-2016)
Valve trainChain driven DOHC, 4 valves per cylinder
Max. power72,1 hp (53 kW) / 8500 rpm
Max. torque66 Nm (6,7 kgf*m) / 7000 rpm – ER6 (2006-2011)
64 Nm (6,5 kgf*m) / 7000 rpm – ER6 (2012-2016)
Type Fuel Injection, 2x Keihin TTK38
Discussion Starter #47
Z650 ABS
Displacement649 cm³ (39,36 cu in)
Compression ratio10.8:1
Max. power68,0 hp (50,2 kW) / 8000 rpm
Max. torque65,7 Nm (6,7 kgf*m) / 6500 rpm
64 Nm (6,6 kgf*m) / 6700 rpm - Z650 (2020+)
Type Fuel Injection, 2x 36 mm (with dual throttle valve)
41 - 48 of 48 Posts
