Looking to swap out the stock eyeball on my 2006 sv650. Anyone willing to sell a full headlight set up (or as complete as available) please let me know!
Only one of the most highly sought-after items in Z1000 history.
Good luck in your search, the parts to make a complete setup are insanely expensive.
Consider this a free bump.
thanks for the bumps. my search is young, but I am open to suggestions due to the difficulty finding a set up and cost.Yes this would make it lok awesome because its one of the most bad *** looking front ends but it will be super expensive i bought the headlight and front cowl for my bike for over $450. good luck bro
options are open. don't know how that would work if I'm trying to keep the streetfighter look though. more research is neededYou can try looking for a Ninja 250, 650 headlight and fairing. The headlights are similar but the fairing it the different part.
Try fabricating a headlight cowl from a 256/650 fairing. Trim it down clean up the edges and paint it. It may be a lot of work though i you can find a some what in shape plastics it may be worth testing it out.options are open. don't know how that would work if I'm trying to keep the streetfighter look though. more research is needed
nice bike by the way.
What he means is that the headlamp/headlight is the same for the Z1000/New model of Ninja 250/650. That meaning if you are piecing this together seperate instead of just looking for the Z1000 headlamp (clear housing with the refelction background that houses the bulbs) you can search for the 250/650 headlamp and maybe find it cheaper. Then slap it inside of the Z1000 front fairing and bracket...if that makes more sense. Google the new ninja 250 and look at the headlight shape vs the Z's and you will see what I mean.options are open. don't know how that would work if I'm trying to keep the streetfighter look though. more research is needed
thought about it, local dealer has two used but I just cleared myself of mc payments this summer and am enjoying that too much to go back in debt. plus the mrs. would flip shiat on meIt may be esiest to just buy the Z1K... just puttin that out there, lol!
interesting. thanks for all the help and ebay searches. I like that look. also, looks like it would give me the room necessary for gauges.Try fabricating a headlight cowl from a 256/650 fairing. Trim it down clean up the edges and paint it. It may be a lot of work though i you can find a some what in shape plastics it may be worth testing it out.
This could be another option since you do have a Suzuki
did not know that atschach. i was hoping not to have to put the headlight together piece by piece...but as I've said, search is young and my options are open.What he means is that the headlamp/headlight is the same for the Z1000/New model of Ninja 250/650. That meaning if you are piecing this together seperate instead of just looking for the Z1000 headlamp (clear housing with the refelction background that houses the bulbs) you can search for the 250/650 headlamp and maybe find it cheaper. Then slap it inside of the Z1000 front fairing and bracket...if that makes more sense. Google the new ninja 250 and look at the headlight shape vs the Z's and you will see what I mean.
I would have to look again but I am pretty sure I looked on BikeBandit.com or another site that sells OEM parts at one point and compared the two headlights and they both had the same exact part number. I would have to look again to confirm.Just looked at the difference between the 2 headlights(Z1000 vs ninja 250)
Now that is dam close....
I wonder if they will mount the same????
