Hi i have a zx14r sprocket and hub that im custimazing to work with my
z1000 07 . The dust seal that comes from factory cant be use because i sanded down the hub 4mm in order to fit wheel in swingarm so i need a close bearing to fit in the hub ............anyone has an idea who sells sealed bearings? thank you
first picture is open seal and sec pic is what i want something close
Were are you located? you should be able to contact about any local bearing supplier and give them the dimensions of the bearing you need and they can get you one with the seals built into the bearing. Or many auto part store will probably have them as well. I believe you are looking for a bearing part number 6006 wich would be 30mm ID 55mm OD and 13mm wide. if thatse are the correct dimensions call the local autoparts store and ask them to cross refference PN 6006-2RS the "2RS" indicates both sides swith rubber seals.
