:glassestiActually, I do believe that is for the Front Axle. I found that I had to go get a 14 mm allen socket to do mine, then I had to add a breaker bar to get it off.
After all, why would a fuel injection bike have a spark plug wrench??
LOLActually, I do believe that is for the Front Axle. I found that I had to go get a 14 mm allen socket to do mine, then I had to add a breaker bar to get it off.
What's this tool for that is found in the tool kit? I thought it was to remove the front axle since it fit in there nicely but after bending the **** out of it trying that, I think I was wrong.
:spit::spit::spit::spit::spit::spit::spit::spit::spit::spit::spit::spit::spit::spit::spit::spit::spit::killingme:killingme:killingme:killingme:killingme:killingme:killingme
awrench :killingmeWhat I don't get is what the other end is supposed to be attached to.
:spit::spit::spit::spit::spit:Actually, I do believe that is for the Front Axle. I found that I had to go get a 14 mm allen socket to do mine, then I had to add a breaker bar to get it off.
Axle was already replaced from when I hit the curb.:stooges: Come on guys, it is a multi tool, spark plug wrench on one end and and axle tool on the otheroke:
unL33T, you probably just bent your tool trying to remove your bent axle after all the times your bike has been down, or could be your turning it the wrong way :smashfrea
Who preformed the replacement ?Axle was already replaced from when I hit the curb.
I think I'll just buy this rather than deal with cutting up allen keys.I tried using that, even with just hand force the metal started to bend / tweak.
We have a set of brass looking keys. 3 are square shapes, the other are hex.
Each one has a different size either end.
I found that I can use those with a torque wrench - I can get the torwue setting correct. Rather than feeling it.
Other than that, pick up a set of allen keys and cut of the curved section.
seriously :blowup::killingme:killingme:killingme:killingmeYes a 14mm allen wrench or hex socket on a torque wrench is the correct method, this cheap multi tool is for more of an emergency road side repair.
:stfu: uhh yea, sirrresly dude. That's why Kawasaki put it in your tool bag you think those tools they give you are for doing full regular maintenance? uhh no, for emergency roadside repairs brah :jerkit:seriously :blowup::killingme:killingme:killingme:killingme
