I can't find the torque settings for the valve cover bolts. Does anyone have this info?
thanks
Ryan
They are small threads, 6 mm I believe. As such they should only be torqued about 5-6 ft lbs. Basically a one handed pinch with a small wrench.
thanks!
This is a bit late, but the manual calls it a Cylinder Head Cover and says torque spec is 87 INCH pounds or 10 Newton Meters. Converting to Ft-Lbs would get you 7.25 ftlbs...
