As the title says I installed LED front turn signals and now the turn signals flash rapidly? The LED flushmounts had two wires, the stock gray and blue went to it for the running/turn lights, and the 3rd was the ground so I grounded it on the original metal bracket. So what can I do to fix this? I'm also getting an integrated rear led taillight soon too so is there anything I need to do to make sure that is fine too? Thanks
For the turn signals, you need to get a load equalizer. that will get rid of the quick blinking on the turn signals. They are telling you that you have a burned out bulb (If I remember correctly, if not I am someone will correct me.). For the tail light, you will not need to do anything.
