Like my Versys but hate the buzz the plastics make. Don't want to take them all off, but it's annoying, although it seems all high-rpm bikes with plastics have it.
You can often times help it. Its easy and cheap to try.
Go to your lock tire store and ask them for some sticky back wheel weights, and try it. Sometimes adding some weight will make them more quiet. Not a lot. An ounce or two max on the back, out of sight.
Reactions: gantt
Also, a little rubber, foam, or felt where the pieces come together.
My '08 Ninja 650 had nylon washers at all the fasteners.
Hi, I had a similar issue with my versys,, I solved it by using the additional stick on pads that are usually supplied with a Bycycle helmet and sticking them down the side of the speedo panel
