I think my transmission may be going on my 2007 Z1000. Bike has ~29,000 miles on it, always run full synthetic oil, changed at least once a year. I ride it hard/fast but don't abuse it (no wheelies or burnouts or stuff like that). I know how to shift and blip/downshift too so I don't consider myself rough on the tranny either.
I've had a couple instances in the past few months when I'm getting on the throttle and it drops out of gear and into a false neutral, maybe between 4th-5th or 5th-6th. Both times it happened it ended up catching after a few seconds once the revs dropped and everything seemed OK.
Today coming home I was entering a corner and downshifted normally, went thru the corner, and accelerated out. When I shifted from 3rd to 4th it dropped out of 4th / hit a false neutral. I can't remember if it grabbed 4th for a second or not before it went into false neutral. Once the revs dropped and I was coasting waiting for it to catch, I heard this awful sound. Like a grinding/rattling in my tranny, like there was a chunk of something bouncing around in there. Kinda like the sound the garbage disposal makes when accidentally put a little bone chunk down there. I probably coasted a good 5 seconds or so before it caught 4th.
The rest of the way home (like 3 minutes) it seemed OK. It downshifted fine and I didn't hear any abnormal sounds, but I was driving very gently because I was expecting the motor to explode at any moment
Should I go drain my oil and see if I see a chunks of metal spill out?
What should I do?
Here's my baby
Here's my baby
