Here's the latest foulup working on my '07 Ninja 650R. I brain cramped and snapped off a bolt securing the head to the lower half. This bolt is one of two located next to the camchain but on the outside of the head. The book calls for 12nm torque and the bolt snapped somewhere around 20 - 22nm. The remains of the bolt are securing head to block. In other words, if the broken bolt were properly torqued I wouldn't need or want to do anything. I'm willing to entertain crazy thoughts and ideas on this one. As I see it my options are:
1. With difficulty, drill out the broken bolt. That may not even be possible because of the location, needing an extender, not being able to use an EZ out, etc. The operation would probably chew up the threads so I'd need to rig a nut and bolt replacement.
2. Leave the bolt in and don't worry about it as opposed to worrying the overtorqued area will warp the head.
3. Use the thinnest cutting tool available to go in sideways and cut the bolt. That will chew up part of the aluminum on the outside but would allow me to pull the head and drill out the remnants.
