for sale is an entire 1st gen motor less the cases. These parts are in ear mint condition, with less than 10k on them. When i tore down the motor this weekend i was amazed at how clean it was. I have no use for these parts as my motor runs excellent. all parts were handled carefully and stored in a clean plastic bin wrapped in shop rags. All prices are OBO. I think they are pretty low to begin with, but if i am way off then we can work something out.
flywheel. stator rotor. $50
valve cover/hardware. great shape, only one minor blemish on the outside above the cam sprockets. no Gasket included. have a spare or paint it to your liking! $25
crankshaft. perfect shape.$40
starter. $20
timing chain $10
timing chain guides. little wear. $10
oil filter holder thingy. $5
Camshafts. super shape. $40
transmission gears. Not sure why you would want them? haha. but maybe someone does. $25. Again, these are really heavy so shipping will be steep. the tape is just to keep them from sliding apart.
Shift forks for the tranny. Pair. no pic but they are in perfect shape. $5.
Stator. Comes with complementary broken cover. The coil looks to be free from any damage. may be useful for someone. $20
stator cover with a hole. it's like a ram air intake for the stator. adds at least 10hp. A must have for the true rider.:silly: $10
thermostat and overflow tank. $10
Wiring harness with ecu and fuse/junction box. has a couple cut wires. Pretty sure they are the front turn signal wires though so no big deal. $45
clutch cover with damage. Rash was painted and looks decent. chipped piece at the top. still functional and could get you by no problem. bearings still inside but no oil window. I do not have that. $30
Other things I have:
ANY misc. hardware that you may need for the motor. I have a gallon zip lock bag full of nuts and bolts from the motor. let me know what you need.
Front sprocket. $5
If you need something specific, just Pm me and i may have it if it is not listed here.
Thanks for looking,
Ryan
starter. $20
timing chain $10
Front sprocket. $5
Thanks for looking,
Ryan
