· Moderator
Stumbled across these the other day at Wal-Mart. Not sure if they'd work. Just seeing if anyone has something like this. This sure would cut down some pre-ride time. Just glance at your valve stems to see if you're in the clear.
Be careful with these valve gauges. The instructions warn that if the valve comes loose, the tire can leak air and go flat. This might not cause a dangerous situation with a car, but with only two wheels on a motorcycle, a low tire could spell crash. Since my safety relies on proper tire pressure for both wheels, I don't want to take the chance that this type of valve will come loose while I am riding.
· The Deer Slayer
Great idea, cheep company. Yhea, your tires probably would go flat from air leak through these caps.
Tony
