From parts lists, evilbay ads, and other web sources the following may be true:
1. SV650 FI appeared in 2003: 39mm throttle bodies, injector bodies were reddish orange (perhaps #25005711).
2. In 2007 throttle body sensor locations were changed, STV control changed to stepper motor(?), O2 sensor(s) added, different injectors - now with green bodies.
Does anyone know:
A. If my information above is correct?
B. If changes in throttle body size or injector impedance or flow rate - or anything else - were made in 2007?
C. Brand, Flow rates, and impedance of injectors?
Thank you.
Chuck
Does anyone know:
Thank you.
Chuck
