Totally agree with you there Marauder! My meanie has the spike as well, and when I was running no map it seemed really good. That is until I checked the plugs
It was running super lean! That was when I posted about maps and such and someone on here (possibly even you..
) Sent the proper map. When I went down the the Wharf Rat Rally in Digby last year, I had the Power Commander guy run my bike on his computer. Cost me about $400, but the bike runs AMAZING now! He said that cause I had moved from Ontario to Nova Scotia the air was different (who knew...) and I needed to adjust my map accordingly. If I play around on the roads and ride her hard then I'll suck fuel like crazy, but if I'm just cruising I get pretty good mileage. My suggestion is to go to a shop that can accurately depict what you need to run for the area that you ride in. Most places will check your "map" for you, but unless you run it on a dyno you'll only be 'playing' with the settings. The way he suggested to me was that the air to fuel ratio needed to be recalibrated if you change anything with the intake or even outtake on your engine. Even changing your pipes changes the back pressure resulting in the engine compensating for fuel:air...
Just my two cents!
