Here's what a thorough rehab of a 2007 650 R looks like (tasks listed newer to older). Numerous smaller tasks didn't make the list. The essentials my 650R needed were tires, battery and chain but I like to go a little further. It looks and rides perfectly now and I look forward to years of it needing only basic maintenance.
Digital gear indicator (EBay $31.80)
Voltmeter and switch (Amazon 9.53 + EBay 9.53)
Thermostat housing gasket (EBay $10.59)
Air filter - Hiflofiltro HFA2606 (Amazon $12.23)
Coolant - Prestone All Vehicles (ethylene and diethylene glycol)
Red silicone coolant / radiator hoses (EBay $26.50)
New clutch cover gasket (Amazon $12.02)
Brakes fully disassembled and pistons polished
Sixity ceramic brake pads (EBay $23.73)
Fork seals (All Ball 56-129 kit with fork and dust seals; $29.70)
Fork oil (10W from on hand supplies)
Rim stripes / decals (EBay $18.01)
Kawasaki Passion Red 234 touchup paint (EBay $13.88)
Valves shimmed with shims on hand
2 - NGK CR9EIA-9 iridium spark plugs (Amazon $21.00)
Cam cover gasket (EBay $31.73)
Haynes Service Manual (ABE books $34.41)
Dunlop RoadSmart III rear tire (Amazon $134.76)
Dunlop RoadSmart III front tire (Amazon $113.76)
Rear brake caliper clean and lube
Sand and hand paint front and rear wheels
2.5 qt Quckilver 10w40 synthetic
HifloFiltro HF303 oil filter
Shift lever adjusted down
D.I.D. x-ring chain 114 link (Amazon $90.10)
First startup 11.25.22 and 20528 miles - idled smoothly, clutch jitter noted (resolved itself first ride)
Mighty Max YTX12-BS battery (Amazon $37.09)
Paint right swingarm side with aluminum paint
Detail caliper bolts
Paint handlebar bracket (aluminum color)
Front and rear brake fluid flush DOT4
Fix blinkers, paint right bar end
Cleanup; replace gas and order battery
Purchase $900.00
PS I left out the parts needed and installed when I screwed up the shim job and replaced the head so I have a 3k mile head now that's been decarboned along with the pistons.
Wheel Tire Fuel tank Automotive tire Automotive lighting
Nice work, doing the same thing on an '08 with 20k miles. Added changing mechanical seal and gaskets, but just broke the impeller bolt, so might have to call in a mechanic. Hopefully these will both runs like new for a long time.
Mine was also right at 20k miles. It was reassuring looking at the inside of the cylinders and seeing zero wear.
