Hi, I'm new here.
I searched up and down (So 2 seconds) for a post about this, and I googled it.
So here I am.
I have a 2010 Z1000, I'm trying to do a clean job of installing all the cosmetic mods this time around, so I picked up a new Flasher relay, new wires, etc so I didn't need to chop the old ones and plug resistors in.
Problem is, I can't find the stupid thing.
If you need pictures of what I'm working with I'll be happy to post them.
I flicked the signals to try and find it with noise, but I couldn't find it due to the fact that the Z1k lives in a very "Echoey" parkade and it simply sounded as if it were everywhere.
Which was quite intimidating.
Anyway, if you can tell me where my flasher relay is and what to do with the new one since I'm not an electrician and McGuivered all the wiring in my last 5 bikes I would appreciate it greatly.
Also, thank you.
I'm pretty sure it's right in the tail section under the rider or passenger seat. Should be a black square box. If you got an LED flasher, you don't need resistors, and it wont require new wire to wire it in. It should just plug into the stock connector.
You are correct sir.
It was tucked in under the subframe pretty flippin' tight.
Thanks!
