I want to be able to mount a ram mount ball on my clutch or break lever mount. Has anyone done this, and if so, which ram mount did you use? I currently have my ram mount on my tree and the tank bag blocks the view.
I know you can get mounts that go on the brake and hydraulic clutch covers for at least some bikes.
Check your bolt spacing on the cover to see if these work.
offset model
centered model
You might also buy a longer arm to go between the current mount and your device if that helps.
offset model
centered model
Thanks
