So tonight as I rolled into my garage I smelled burned oil, after a quick inspection I found a small hole just behind the water pump which leaks couple of drops of oil in small intervals, while the engine is running.
It almost like a pressure overflow or similar, I quickly glanced on the repair manual, but could not find out what it is and why does it started to leak all of the sudden.
Two pictures, arrows are pointing to the hole, any idea what is the problem, how to fix it?
Thank you!
Thank you!
