1 - 7 of 7 Posts
so how long does it take to install a PCIII in a 2007?
i'm wondering if i should wait until the weekend or try and tackle it after work during the week.
wait for the weekend that way you dont have to rush. You can route the wires nicely and you have time incase u run into any snags.
Took me about two hours start to finish. I suggest soldering the connection at the TPS instead of the quick-connector. I tried the connector and it was fairly loose, so removed, spliced, and soldered.
Note the PCV comes with an adapter plug for the TPS so that you don't have to clip into the stock wire. Of course I did clip into the stock wiring for the speed signal though.
it wasn't that bad of an install. the hardest part was finding the [email protected] TPS wire!
also i didn't figure out how to fully disconnect the fuel tank until i was 1/2 way done. oh well better late than never.
1 - 7 of 7 Posts
