1 - 2 of 2 Posts
Hi all,
I have an 02 Mean Streak that came with a PCII installed. No idea if it was Dyno-tuned. I had to disconnect it to swap the engine into another frame and can only find PCIII instructions. It appears the wire color coding used in the PCIII instructions seem to be different than the PC II. Can anyone confirm that the PCII and PCIII wire colors are the same? Anyone have some PCII installation instructions?
Internet searches seem to only bring up PCIII instructions.
Discussion Starter #2
Sorry my bad. It is a PCIII on the bike. I have followed the instructions except for the ground wire. PO had it wired directly to the negative post. Instructions say should go to the Black with Yellow tracer aux. ground. I have found said aux. ground and can get the male connector. Is it critical to use the aux. ground?
1 - 2 of 2 Posts
