Hi guys please help i have just bought an 04 Z750 with 44000kms on the clock, the bike pulls terribly, but even worse after 6000rpm there's no power and it just like bogs down all the way through the revs , it also is running very hot. So again up to 6000rpm she seems to pull fine then nothing any ideas? My pipe is also burning very white? IMG_20180919_071456.jpg IMG_20180919_071612.jpg IMG_20180916_133315.jpg
You've posted this in the zr7s section and might not get as many helpful replies as while similar our model is not fuel injected or water cooled.
Check your coolant level. Hopefully it's fine. If not you may have a bad head gasket which could result in the poor power, overheating and white in the exhaust.
Thanks bud
