1 - 2 of 2 Posts
I've drop by oil pan clean the filters three or four times run gas and stuff through the motor to clean it out it's clogged up I think in the top end of the motor how do I clear out the oil lubrication Passage how do I blow it back through it's knocking real bad because it's not getting oil to the top half I had some issues with the Chang coming off and bus in the oil pipe so I got that all fixed and now I'm having other issues hoping it's not my oil but the oil light's not coming on so that makes me leery of it being that I think it's clogged any suggestions on the best way to unclog it
Holy grammar and punctuation...
I'm not too sure what you're trying to say other than your engine is knocking. Who is Chang? I doubt a bus will fit in any oil pipe.
All kidding aside, can you be a bit more clear on your symptoms and how you diagnosed a blocked oil passage?
How's the oil level?
Any overheating issues?
If a passage is definitely blocked, you can open things up and shoot some air in there to force out any gunk.
Also, low octane gasoline can cause knock.
1 - 2 of 2 Posts
