1 - 9 of 9 Posts
Anybody have any recommendations on oil and/or fuel treatments? Carb cleaner mixed with gas? Slick 50 in the oil? etc. etc.? Or just don't do any of the above?
Kelly
Wheelie for Safety
The reason those products exist... is best described by the saying: "A fool and his money are soon parted"
Bottom line, if it ain't broke don't fix it.
Andy
Andy- well, yes and no. I'll give you that on stuff like Slick-50, Marvel's Mystery Oil, and STP Oil Treatment. But you gotta admit that a reputable brand of $2.00 carb/injector cleaner every couple thousand miles certainly can't hurt, and they are generally regarded as a good thing to do. At least for cars anyway.
I never heard any recommendations one way or the other about bikes. Maybe if you live above 8K RPM you don't have to worry about it. ;) So I should be fine.
I agree about the aint broke-don't fix thing, but how about the spoonful of prevention is worth a pound of cure thing?
kelly
Wheelie for Safety
I never used carb/injector cleaner in any of my cars or motorcycles, and can't remember having any problems due to not using it. Gasoline is a pretty good solvent.
Andy
As long as you run it regularly, you shouldn't need all that stuff.
Additives
Kelly,
I have never used an oil additive - IMHO don't use them if for no other reason than the wet clutch may not like the additive. Just use a good quality motorcycle oil and change it often.
Fuel additive - I have had a fuel tank rust through a few years back so every month or so I use a carb cleaner additive that absorbs any condensation that may accumulate in the tank. Maybe it helps maybe it doesn't but either way it's only a few cents in the long run. Another thing I try to do is make sure the tank is full when I'm not using the bike for a while as this also helps to reduce the condensation problem inside the tank.
Just my 2c worth.
Glenn
Silver Member
Fuel : I just use premium unleaded which is supposed to have solvents in it. Occassionally I will 50/50 mix a tank of premium unleaded and leaded ( or lead replacement ) fuel, just to give the valve seats a break. Don't tell the EPA.
Oil : I only use top quality Shell Advance and change it regularly. Normally I wouldn't use synthetic in an air cooled motor but it seems to work fine.
The only time I use STP/Motor-up etc is if I have an oil burner I am trading in to a dealer. Need that top $$$ :D:D:D
1 - 9 of 9 Posts
