21 - 35 of 35 Posts
Discussion Starter #21
Discussion Starter #22
Will try to test fit the swingarm//shock this week - and possibly start rebuilding the headlight with projectors but will probably wait till all the brackets are in
- Stay tuned though, the build continues???.
Discussion Starter #24
Got the rear shock, swing arm and steering dampener on.
Also received the 2003 Z1000 Headlight/gauge/windscreen stay; needs a couple mods to work but should turn out good once installed (way less labor intensive than making one from scratch)
What's left:
Fab for the subframe
- Minimal fab for the headlight stay (as well as projector install)
- chopping un-needed brackets
- powder coat
- paint
- assembly left ?
--> Let's see how long this takes lol
122112
122114
122113
122115
122116
Discussion Starter #26
Ran into a slight problem, my dampener's shaft isn't long enough and won't allow for full lock to lock turning - any suggestions?
As for the engine, I just have a Two Brothers slip on, and a power commander - will also probably do the air-box mod (link in first post) - there anything else that could be done with keeping reliability?
I used a cheap eBay bracket and put it near the triple. I imagine you put it down on the side for the look so the only thing I can think of is move the pivot point closer somehow. Otherwise get a longer damper or relocate to the triple..
Id say just get a higher flowing filter. the power commander is great if you also have the auto tune and all the rest. Gets a bit price prohibitive which is why I was asking ... need some ideas myself :) Ive compared the PC, Bazaaz and also Woolwich racing stuff and it all lines up around the same price if your going for an autotune setup for fuel and ignition.... Id love me some of that ,as well as a quick shifter.
Discussion Starter #28
The silver part in front of the dampener is a 50MM cheap eBay bracket - I was possibly thinking of making a vertical mounting point off the frame (right in front of the gas tank) since the versys upper has 4 holes with threads --> this way the stick dampener will act as most SS bike's stick dampeners (on top of the triple tree)
What size dampener did you purchase/ where did you mount it to the frame? Could you post some pictures of the setup
In addition - it seems I'd be able to use dirt-bike bars if I made custom H clamps since the upper has the threaded holes - will try the clip ons for the beginning though
I used a bracket like this one(mines a 2010 but it might fit ?)
Never taken a good photo of how it mounts to the frame I don’t think because it’s black and dark in there it’s hard to get a pic in focus.
You’re a lucky guy ! Found some pics of the bracket when i was installing.
Because i had risers under my bar clamp(i was using a drag bar at the time) i had to get a longer bolt and space it up a bit. The other end bolts on top of the z1000 top clamp (two little collars space it up as part of the kit) but its actually made for a Ninja 650 clamp.
Discussion Starter #31
Can you post a link of that frame mount? That's what I wanted to fab up but that looks much better
I wouldn’t buy this myself because its a structural member of the bike. It’ll probably be ok but you just dont know what the thing is really made of at this price but a top triple like this with an integrated mounting point would be nice.
The ad says durable...lol
Slow moving on this project;
These thing always take longer than needed...
I wrote that because that’s my experience. Usually it takes 3 times longer than I estimated :)
There’s a guy over on a custom bike forum who’s built some incredible ****... his advice ....no matter what happens do one little bit of work on it every day to keep things moving but also to keep your motivation up..or something like that... the guy built his own frame in his shed that barely fits a bike....he knows his stuff
In addition; I saw this build thread - https://www.kawiforums.com/ninja-650r-er6/315842-looking-advice-suspension-upgrades-other-bits.html
And really like the way the EN-6R Belly Fairing looks - so think I will be adding this in as well
Don’t know how I missed this part of the post but if you need pics of brackets or any other part of the belly pan lemme know.
21 - 35 of 35 Posts
