Hi guys,
A picture says a thousand words as they say..please watch a YouTube video explaining the problem..
In short I've been told there's a problem with the throttle body during start up, when i push the starter all i get is a 'dead mans click' from the relay..
Try cleaning the connectors to the starter relay. Pull it out and use a fine brass wire brush on the threads and on the end of the leads so that you have a good connection - even a lose nut on the relay will lower the voltage through the relay and all you will get is a click. In humid climates corrosion can build up between the connections, thus dropping the voltage. The noise of the sub throttle body actuator doesn't sound to good. Seems like you have a combination of problems.
Also check the Reg/Rec
