1 - 6 of 6 Posts
I'm still getting over a large blister on my throttle hand from last month's ride up to SB. I had removed my Grip Puppies because they'd been just a little too big for everyday riding. I had them mounted over my previous Pro-Grips but they increased the reach to my brake lever to a point that just wasn't safe enough for my stop & go commuting.
GRIP PUPPIES ™ Small. (1 Pair) - Motorcycle Parts and Accessories for the Sport Touring Enthusiast at California Sport Touring
So I saw a good review of the Spider Peak Road Grips, so I ordered a pair and finally installed them today.
Introducing the New Spider PEAK Grip! ? Spider Grips
I cut off my old pair of Pro-Grips, model 732, which were showing signs of wear though were never quite think enough to be as comfortable as the Grip Puppies.
I removed the bar ends (6mm hex wrench, I think) and tried to slide on the Spider's, starting with the left side. No way was it going on without some help! So I got an old travel-size bottle of hair spray, wet down the inside of the new grip and it slid right on! I never would have got it on without the hairspray and I still have no idea how you put grips on using compressed air!
I had no more Scott's Grip Stick glue, which I have been using as insurance with other grips. We'll see if they hold.
You should be wearing gloves. But are you sure hair spray won't make them slide while you are pulling the throttle?
The Hairspray is an old trick. Once it dries it forms like a glue.
I am very interested in your thoughts on these grips. I currently have the Driven D3's, and I am not a huge fan.
Discussion Starter · #5 ·
I wouldn't have thought I'd needed to mention that i WAS wearing gloves but I guess some guys don't...
I had on my padded Cortech Vice 2.0 gloves:
Cortech Vice 2.0 Gloves - Street Bike - Motorcycle Superstore
The hairspray dries quickly and becomes very sticky. My hands were tacking up within seconds of getting a little wet. Even without anything sticky, the grips should hang on tight to the bars. Try pulling on a grip without any hairspray, like I tried, to see how impossible it would be to even twist these grips loose.
They feel beefier than the old ones and they are a little thicker in the middle. Not nearly as much difference as Grip Puppies, but they do seem a bit more thick than the Pro-Grips.
1 - 6 of 6 Posts
