1 - 6 of 6 Posts
Has anyone had any trouble with the neutral light.
Mine has started coming on intermittantly in all gears.
Iv'e a hunch that the switch may be faulty and require replacing.
Before I change it though I thought it would be a good idea to check with you guys to see if it's a common fault.
Cheers-----------------
MotoMacGyver
Nope. Never heard of that as a problem. It's probably at the switch by the gearbox itself. Maybe there's corrosion or something. Does it prevent you from starting the bike if the light DOESN'T come on as well?
Emrah
I haven't had any troubles with this one. I don't know how this one works, but I had one once come loose on another bike and it did the same thing.
Silver Member
No problem I've seen. Only time light comes on when not in neutral is when I get lazy w/ my shifting. Normally @ low speed, when not paying a lot of attention.
Thanks for the advice guys, believe it or not the fault has not shown up for the last couple of days. So fingers crossed I might be in the clear. If it comes back I'll check the switch.
Thanks------------------------
1 - 6 of 6 Posts
