I have a wiring diagram from a 2009
I think you’re on the right track. the gauge has permanent power to pin 1.but the neutral switch is powered from ignition (pin2) Disconnect pin 1 from gauge and see if that fixes it? If it does then that means that there’s leakage across circuits within the Gauge cluster itself. To prove it apply power pin 1 and ground pin 3 to gauge (leave ignition power off(pin 2) on a bench and earth the neutral pin. If it lights up on a bench it’s the gauge. If it doesn’t it’s the wiring. …. I think …. Hope I helped in some way
