I have a small drip on my fuel switch when it is in the down position. I am guessing there is some washer or something behind the knob that needs to be replaced. I canot find a sizing or part ID though. Can anyone help me out?
I presume I can just pop the faceplate off and swap this thing out too. Any surprises waiting for me?
The parts microfiche shows 2 parts that fit your speculative desciption:
P/No 43049-1066 PACKING,TAP VALVE and
P/No 92055-1419 RING-O,TAP LEVER
The tap valve packing appears to be a circular shaped disc that acts as a disc valve and selects the correct input/output from the valve.
The O ring is just that, an O ring.
Fuel valve/tap overhaul kits are often available on e-Bay.
If you have worn parts in yours a complete overhaul may be your best option.
Please do not post copyrighted material here. Links to the material are OK.
Hope this helps?
Perfect, thanks guys. After a search online it looks like the overhaul kits are basically just a bunch of nylon washers to swap out.
