1 - 2 of 2 Posts
Dear all,
I bought a used 2010 Suzuki Marauder 1600 (identical to the Kawa Mean Streak) with a Muzzys 2-1 Megaphone exhaust installed.
Unfortunately, it was installed by the second-last owner amdi have no information about it, hence, I hoped that you could please help me :)
There are no other changes made to the engine not the air intake.
I am wondering if only the exhaust installation needs a fuel adjustment (e.g., with PC-III) or if the is not required?
I am genuinely a bit concerned that the engine might run too lean and overheat.
However, from inspecting the sparks it looks OK.
Any chance someone here with the same exhaust could help me?
Thanks a lot!
I don't have the same exhaust or bike, but I can tell you that you probably aren't going to have any overheating issues with your water cooled engine from just adding an aftermarket exhaust. Your plugs also don't look like it's running lean at all, which makes sense because with the stock intake the engine is getting the exact same amount of air as it was with the stock exhaust.
If you do add an aftermarket high flow intake, you'd definitely want to add a tuner, but for now you should be just fine.
Sent from my SM-G965U using Tapatalk
1 - 2 of 2 Posts
