1 - 20 of 31 Posts
PM Speed racer he's ot a bullet fairing mounted on his Marauder.
Just so others know,just received Vulcan custom bullet fairing and ms sportshield mount to my 02 meanie,headlight hole is 3/4 too small and lower triple tree is in the west for a clean mount. I'm going to have to make custom brackets to make it work. Will post some pics when I'm done.
Yeah, pretty sure speedracer used a Vulcan headlight and made/bent the brackets to fit.
meanie head light will work, but will stick out a little farther than mine. I only had to bend bracket because of the rake. Other than that the classic headlight is a perfect fit. bracket bolt holes line up fine. I drilled out the holes though so I could use 8 mm bolts.
Discussion Starter · #10 ·
I assume it is the stock light, I used the custom 900 fairing but the hole was 3/4" too small,had to make new mounts to attach the Memphis shades sportsheild mounts go up 2 3/4. " up and 2" out to make it work, all in all I like how it turned out
i agree more pics would be great.
I have finished the install, made some brackets, turned out like I wanted it too. Thanks to all who helped point me in the right direction ! View attachment 83584 View attachment 83584
I hope I did not steer you in the wrong direction on the right fairing to use. For some reason I thought the 900 custom light and the meanie were the same size. I guess the custom is 7". Again sorry if I messed you up
Back from the dead?
Not to awaken an old post but well...here we go.
It didn't seem like the OP ever resolved his issue and it looks like you (speedracer) had marginal success yourself I was just wondering if you had any info on
1. What make and model of fairing you used
2. What you put it on and what your measurements are (someone indicated it was a marauder?)
3. What you had to do to get it to work.
I'm looking to add it to a 2006 Meanie I think has the stock headlight and I want to make sure I get the right thing before dropping the money on it. I can take measurements just looking for a jumping off point.
Any help you can give I'd greatly appreciate man!
also looking for one on my 2005 meanie , have a m109 windshield on my 2002 meanie but looking for a different look
Yes, I'm also wanting to use a fly screen or preferably a Bullit fairing... any more info on this topic would be cool, and any pics please post!
Cheers
I used the bullet for fat boy. Used Memphis sport shield brackets. Used vulcan 1600 classic headlight and mount,. You mount bullet first then headlight. Tight fit but looks good
Sent from my LG-H918 using Tapatalk
speedracer love the fairing
found MEM9934 Memphis Shades Sportshield , are these the correct brackets?
also you used fatboy bullet shield is this because of the Vulcan headlight ?
wondering which fairing to order . thanks
1 - 20 of 31 Posts
