Hi folks,
My 2006 Ninja 650r had the dreaded water pump seal failure - started dripping coolant from the weep hole, followed by boiling noises in the radiator.
I took it apart today - the impeller was extremely difficult to remove and I ended up damaging it. After pulling it and the flat-ish plate/housing that holds the mechanical seal, I found milky fluid and a good amount of gunk behind the flat housing.
The milky fluid I don't think is surprising - some coolant mixed with oil here. But, the gunk on the bottom here surprised me. Most of it clears out easily by wiping; around the impeller though it was solidified into a hard, plastic-like substance.
See photos below - am I good to just clean this out as best I can, replace the water seal + oil seal + impeller as typical, and go on my way? Or is there any concern that this gunk is in places it shouldn't be?
(When I drained the engine oil, it looked good - no milkiness etc.)
Thank you!
Thank you!
