1 - 6 of 6 Posts
hey everyone,
My 2007 meanstreak kinda bogs down/loses power on the freeway and it only really happens around 70+. Will be steady on the throttle and it will just cut off for a split second and then continue on its way. Any ideas?
Sorry, there is vance n Hines pipes and I do have a pc3 I believe I just never messed with any of it because I'm not very mechanically inclined.
Start with the basic stuff first. Make sure your air filter is clean. Run through that procedure to clean the throttle body and use some of the Seafoam in your gas as well.
Honestly, that sounds like an issue with fuel getting to the engine. Could be the PCIII having a faulty map or perhaps something is wrong with your fuel injection. If it's happening consistently at the same speed/rpm I think it's the PCIII. Did you have it dyno tuned or did you use a pre-loaded map?
1 - 6 of 6 Posts
