Wondering if you could help me out with a problem I have with a vn1500 meanstreak 2003 I got a while back the speedometer was broken so not sure of mileage
The bike was running ruff but had been sitting a while
I ran her with injection cleaner etc and got her goin
I noticed she was using oil I had to top her up considerably but doesn’t appear to be putting out any smoke etc actually runs fine
I then decided to fit the cam chain extensions on the adjusters
When I took them out they where at full adjustment
Could have been like that for a long time
Well I fitted the extensions
And when checking the oil Assy filter at the sump there was like a thin piece of plastic and what appeared to be like a hard foam which I suspect is the the cam blade
I have rode the bike since a few hundred miles
Decided to do the oil again
And there was a lot more of the foam I described
Is it a big job to go in and replace the he blades
And if I do decide to take this on
Where do I start
What do I need etc
Do I need to replace other stuff when I’m in there etc valve seal ,gaskets
Can’t afford to pay someone I’ve a lot of money in the bike as I restored it paint etc to get it where it is
I would really appreciate your help and advice
Where do I start
What do I need etc
