21 - 31 of 31 Posts
what map are you running now? I am going to try and get mine on the dyno in a few days. Maybe monday
Run your bike to the hotel Here in Hilliard..I have the maps on my laptop..
Bring a jump drive with you too and I will load you up with what I have...
Rick,
Mine is running way hotter than usual. I need to try a different map. It acts way rich at low throttle, and lean at the top. MPG is around 35-37. I am going to see if Aaron will run it again to try and work it out. That last run was a little qwerky.
Guys, Tried to unzip both files and Winzip is say they are unsupported. What format did you guys zip them in?
Are you going to be there Rick? Still planning on it unless my bike is broke :eek:(
Try the last map I sent for grins..Fuel table 2 was running lean for me as well..I gave it a good trial and noticed the vibration at 3K was gone, engine temp wasnt as hot and loads of power.
Hey Rasmith, what map are you referring to in this post? I have downloaded the yaeger.zip maps. I am currently using Carvedup's economy map, it works well, but I am getting a vibration around 3k, thats why I wouldnt mind trying the last map you refer to.
Dean
Dean
Im using the Yeager map but Im getting the same vibration..Not too bad but I notice it and right about 3K too..
Im going to be there..My niece is going to ride along and hold the poker hand..
Need to figure a meetup place. I'm flying back to KC early tomorrow so I'll look at place thats easy to get to.
21 - 31 of 31 Posts
