1 - 7 of 7 Posts
I lost the keys to my z, I can either bring the whole bike into the locksmith or I can take in the lock cyclinder. I stared taking out the lock cylinder and I got it to the point where it looks like there are two rivots or bolts with a round head holding them in. I was wondering if there is anyway to take these off without drilling them out.
you might have to heat them up to make it loose at work we usually heat them up a little and cut the screw right in the middle with this tool deep enough for a thick flat screw driver to make it turn . the trick is to make the cut deep so when you turn the screw it does brake in 2 . This is the tool ( this things are design to be cut once you maybe getting another set of screws would help
They are security bolts-the heads are designed to break off if you try to remove them. They must be drilled out. Kind of a pain, but do-able. BTW, that cutting wheel will make a mess of all components in that area. Stick to the drill.
Take your VIN to the dealer. They will be able to cut you a new one without the metal tag that had the key code on it. I did this a few years ago when I left my keys in AL and hauled the bike to OH.
Not all dealers will cut by the VIN. Tried that with my Yamaha and got a big "no-can-do" from several dealers. My solution was to take the bike to a locksmith who was able to "read" lock cylinder and promptly (read; on the spot) cut a couple of new keys. Sorry bro-there isn't a quick-fast-and-in-a-hurry fix for this one.
Might as well call the dealer first and see if they can do it. better than cutting out rivets if you don't really have to.
1 - 7 of 7 Posts
