Hey guys, my clutch lever is pretty loose on it's vertical axis, as in when moving he lever up and down theres a lot of wiggle room. I thought that I could simply tighten the nut on the underside of the clutch housing, but theres a black box screwed to the housing.
Easy fix I thought, until I found out that the two screws holding the black plastic part (Not sure of the name) in place had lock tight and I'm afraid of stripping the second screw. Pretty much I can't get the screw out to make enough room to slip a socket head over the nut to tighten down the lever.
Any advice on an easier way to do this that I'm not thinking of?
