1 - 1 of 1 Posts
2000 zr7,
Recently acquired this bike, had some odds and ends replaced and missing that I tracked down and replaced, new electrical harness, carbs were rebuilt(not by me).
Well bike is all together now, but I can't get it to stay running, I've rerouted cables, changed plugs, even pulled the carbs out again to clean(sediments were present). Well I get it all reassembled, airbox with new filter, all the hardware too, and the first start of the day it will fire right away, and then die. If I snuff the airbox opening, I can get it to restart, otherwise it will crank till the battery dies. I've worked on bikes before but never a 4 bank carb set up.. am I missing something, or can you veteran zr7 guys point me in the right direction
Thank you,
1 - 1 of 1 Posts
