1 - 9 of 9 Posts
All finally installed in the last week. This was the first experience with the Vortex sprocket - wasn't impressed with fit for the chain. Pull the chain at the end of the sprocket and it feels/looks like the chain is 25% worn. Oh well. It'll most likely last a couple of summers. I went up from a 42t to a 44t size sprocket. I recommend this size to anyone. The accelerating is so effortless for the bike. I credit more the the lower gearing than the exhaust. The slip-ons have a sound reducer between the mid-pipe and mufflers - gotta like that reverse cone look. Sound might be a bit louder than I would prefer - it did take two years to want to get an aftermarket exhaust because I really like the quietness. Burbling is minimal during decel even with the K&N filter. Have to ride more for a better opinion on that.
[/IMG]
[/IMG]
Definitely a sick bike! Love the white and red. Curious what your thought process was on mixing in the orange though (why not red, white, or black)??? . . . Not that an explanation is needed; it's your bike.
P.S. seems as though I may have stole your idea for my signature. . .
Discussion Starter · #5 ·
The color is the OEM candy burnt orange from Color-Rite. The photo and monitors make it look red. Much better in person as it matches the fork tubes.
If you car use one bulb to give both High and Low beams, that means your current bulb have two filaments, or we called it
Dual Beam Bulb; If you need your high beam to work properly, then you should buy a Bi-Xenon HID(our model bulb-3) which gives
you both High and Low in Xenon.
This high beam will work correctly and will point where you tell it to. Bi-Xenon bulbs usually come with 3 wires per bulb.
They also come with a control unit that handles the low vs high beam.Bi-Xenon bulbs can move, so you can have one bulb to
give you High and Low. http://www.vvme.com/hid-conversion-kits-bixenon-hid-conversion-kit-c-44_46.html
1 - 9 of 9 Posts
