Whats the biggest tire we can put on stock rims that will fit without modification.Will a 190/55/17 fit the rear
I'm pretty sure that shouldn't have made any difference to your speedo. The sensor is located in or near the gearbox, and since I'm assumeing you haven't changed the gearing on your bike, there shouldn't be any physical difference.i put a 170/60zr17 mich road pilot2 on my 09 650r today 0 problems infact i went threw three radar detectors and now my speedo is only of by 3 miles n hr instead of 5
your wrong...when you change the diameter of the tire you change the number of revolutions in a given distance which will affect your actual speedometer since it only reads the revolutions n the gearbox-sprocketI'm pretty sure that shouldn't have made any difference to your speedo. The sensor is located in or near the gearbox, and since I'm assumeing you haven't changed the gearing on your bike, there shouldn't be any physical difference.
Hopefully someone can confirm that for me, or correct me if I am wrong, I don't mind either way!!!
